Re: Gear reductions (Howard)
Posted by mkirsch on July 08, 2013 at 04:51:15 from (64.80.110.74):
In Reply to: Gear reductions (Howard) posted by co2cub on July 07, 2013 at 16:12:58:
I think I could eat the grass faster than that tractor would mow it with dual speed reducers... Can you even see it move?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
