Re: Farmall Super A touch control rebuild
Posted by Dalex on July 08, 2013 at 10:25:48 from (108.38.146.180):
In Reply to: Farmall Super A touch control rebuild posted by chad from michigan on July 08, 2013 at 09:22:12:
I'd rebuild the cyls first, The packing kits are cheap , and they are the problem 90% of the time . The rubber and plastic parts inside wear out, letting the hyd pressure leak past them. Even if they don.t leak externally , they can be worn and leaking/bypassing inside....
