Your problem at high idle may not be the vertical linkage. First with the engine off, take the side cover off of the governor and see if the high idle set screw is against the housing. If not you probably have sloppy linkage from the throttle handle to the governor. Once you get the high idle speed where you want it, then do as was said above and adjust the vertical linkage so the pin just slips in at wide open throttle position. If your engine has had fire craters installed, it may have the 22 degree advance instead of 25 degree.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
