Also check the throttle linkage. After years those tractors are bad about loosing movement from the throttle handle up to the governor. When full throttle make sure the governor arm is at it full travel as a first check. Also if the engine stumbles and tries to die when going to slow idle it still needs to be in better tune. You didn't say how you are checking RPM. Factory tach or other?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
