Posted by Larry B. 1486 on July 08, 2013 at 19:17:24 from (98.19.163.140):
In Reply to: 1086 running warm?? posted by farmallday on July 08, 2013 at 06:57:46:
I custom baled for over twenty years and you radiator may be plugged up. My 1486 would run close to the red at times when the radiator would suck a lot of hay dust in the fins. Clean it out and would be back to normal. I had another one that did that also and it turned out to be clogged up on the inside. Took it to the radiator shop , got it cleaned out and it ran normal again also. The gauges on our 86 series all work and when running normal the gauge never gets half way even under a heavy load in the summer heat. I also changed the fan blades on all mine from 6 blade fan to heavy duty 8 blade fans. Makes a difference.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
