Well lets start back at the Gov. does the spring flop around in big holes in the two arms?? mover then likely the bushings that USE to be pressed in the arms are long gone and this is not pushing the linkage back to dead ideal . Next as to not getting WOT the rest of the throttle linkage is plum slap wore out from to many year doing what it was suppose to do . Every hole that the linkages goes thru is to big and needs FIXED . Once you have that all tightened up THEn you do the gov to carb adjustment. Then it would be a look at the dist.And that needs done buy some OLD FART that knows how to do this and that has the OLD equipment and knows how to use it as this is becoming a dying art . There are not many of us OLD guys that know how to set the centrifugal advance and correct for ware . I did one of my friends 400 last year and made a new tractor out of it .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
