Re: Super H transmission oil level
Posted by caterpillar guy on July 09, 2013 at 04:29:30 from (75.134.172.124):
In Reply to: Super H transmission oil level posted by burnsg2003 on July 08, 2013 at 06:07:05:
Underneath there is a hole in the bottom of the casting. In that hole is where you grease the pilot bearing. Turn the flywheel till it lines up then you can grease it. Don't bump the starter with your finger in there to find it, have some one turn the fan or pry it with a bar through the starter hole.
The plug in front of the clutch pedal on the left side is your oil level. If it doesn't have the TA you can use 80-90 gear oil. Or if changing completely you can put Hytran in there. Probably will give some leaks on old seals from time and wear though.
