Posted by gene bender on July 09, 2013 at 05:52:05 from (67.55.227.12):
In Reply to: Re: Stuck H posted by Alderman on July 09, 2013 at 03:50:26:
Yes they get stuck real ad sometimes and the best is just loosen up the starter from the engine. Take a good look at the bendix and the teeth on the ring gear when you have the starter out. If the flyheel ring gear is bad you mite need to replace it. Usually a new bendix will help a bunch. But in time the ring gear will need replaced if that area is real bad. But you realy wont know till the starter is removed when its locked up. Engines will usually stop at the same position.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
