Re: another water pump question(farmall H)
Posted by Nathan Rigg on July 09, 2013 at 13:47:11 from (71.51.98.59):
In Reply to: Re: another water pump question(farmall H) posted by pete 23 on July 06, 2013 at 20:10:49:
Ok. So there must be something I'm missing. Because the bearings and seals can't be driven out from what I'm seeing. I am looking at both sides and I see the seals on each side with the two bearings and the bearing spacer in the middle. However both sides are to narrow to allow the seals and bearings to be driven out. It looks like one side may be able to be removed but it won't budge. So I think I'm missing something.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
