One bearing and one seal come out each end. Pry out the seal and then drive the bearing out. The center of the pulley casting is smaller that the OD of the bearings. The bearings are pressed into the pulley until the OD bottoms on the machined area. The center tube is there so that when the retaining nut is tightened the bearing ID is held in place without applying pressure on the OD.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
