Posted by Larry B. 1486 on July 09, 2013 at 17:58:55 from (98.19.163.140):
Have some hyd problems on my 1486. I only have 1,800 psi on the external outlets. I have changed relief valves on 706 thru my 1466 that screw in on the right side of the lift cover but never on a 86 series with a cab. Do they use the same relief valve as the 06,56 and 66 series tractors? Is it located in the same location as well? A few years back when I checked it, it was putting out 2.400 psi. It struggles now to pick up the bat wing bush hog. The filter is good and oil level over the full mark. Though I would start with the valve before I pull the pump. Thanks for any help.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
