Re: Farmall H backfires
Posted by Shop teacher 94 on July 10, 2013 at 11:01:21 from (50.33.62.191):
In Reply to: Re: Farmall H backfires posted by Shop teacher 94 on July 10, 2013 at 10:32:10:
Sett the main Jet adjusting screw to mid way. then set the Idle air adjusting screw to mid way. Tractor fired. Died...i tapped on the magneto...fired right up. Thinking the magneto is sticking....is that possible?
