Re: F-20 Magnito
Posted by Tom Fleming on July 10, 2013 at 17:30:13 from (67.20.233.75):
In Reply to: F-20 Magnito posted by Jake in Iowa on July 10, 2013 at 16:55:18:
Jake, there are a couple of things to check. First off, clean the points up and make sure they are gapped correctly. 2ndly, make sure the impulse is working. 3rdly, make sure there isn't junk in the points area that would short them out.
Start there. It could also be the condenser, it could be the coil. Could be a grounded wire from the points. could be a number of things, but start with the easy ones. Expect to pay around $125 - $150 to have the F4 rebuilt. If you choose to do it yourself, you will have around $70-$80 in parts. That would be points, condenser, and coil if needed.
