F-20 Loud transmission
Posted by EM Iowa on July 10, 2013 at 19:37:15 from (67.55.190.168):
I posted a question earlier about the transmission being loud after I swapped the innards of two transmissions. I believe the noise is a gear on the top shaft sliding around a bit and catching on the transmission shaft below it (a loud chattering noise). I've put two top covers on (Thought maybe a fork had something to do with it) without a change ion the noise. Is there anything I can do? Will it get better once the tractor is running?
Is welding up a fork a possibility?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
