Re: How to tell if a tractor is positive or negative ground?
Posted by Brad in WI on July 11, 2013 at 05:35:15 from (108.167.199.164):
In Reply to: How to tell if a tractor is positive or negative ground? posted by Brad in WI on July 10, 2013 at 19:22:07:
everything worked very well except for my neighbor when removing the battery galled up a top post cable clamp that is too far gone to repair and pryed it off and broke the post from the plates on the inside of the battery. He did not know a battery could be hooked up either way and did not pay attention when he took it out. It was removed because it only had 6.2V in the battery and he thought it was bad. He then tried to trickle charge it for a few hours on a 12V charger. He only took it out because the tractor would not start. Turns out that he had the tractor flooded and thought it was the battery cause it turned over slowly. Brad
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
