Re: How to tell if a tractor is positive or negative ground?
Posted by pete 23 on July 11, 2013 at 11:34:09 from (74.32.227.210):
In Reply to: How to tell if a tractor is positive or negative ground? posted by Brad in WI on July 10, 2013 at 19:22:07:
Most likely positive ground. If lights work it is easy to tell. You indicated it is 6 volt system so I will assume still generator not alternator or all bets are off. You can hook a couple of small jumper wires to battery, starter and ground. Turn lights on and if hooked correct the ammeter will show discharge. If hooked wrong it will show charge which of course it is not charging as it is not running. Even hooking it backwards will not cause any harm if you do not start it. If it has alternator, then I would hook a test light between batt post and ground. If it lights it is hooked wrong unless you have something turned on like lights or ign.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
