Re: Gear oil amount...
Posted by D Slater on July 12, 2013 at 15:51:22 from (184.14.197.13):
In Reply to: Re: Gear oil amount... posted by BigTone on July 12, 2013 at 14:56:41:
Only 2 transmission drain plugs on a M. Other one is a smaller one at the front of the transmission housing. Fill to the bottom of the check level plug on the left side of the transmission.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
