Re: Farmall C charging system will not work
Posted by JMOR on July 13, 2013 at 05:57:40 from (72.181.173.171):
In Reply to: Farmall C charging system will not work posted by Nick M. on July 13, 2013 at 05:40:51:
Something definitely wrong with generator, because you are able to make it run CCW. Very likely the fields. Generally 6v fields run about 2 to 4 Ohms, so you might learn something by measuring that. I say might, because of the wide range & if/where a winding to winding short might be. You could check for field to case shorts by lifting the brush connected to field & armature (remove it or slip a piece of heavy paler between it and armature) and then use Ohmmeter to verify that there is open circuit between case & fields.
