Re: Broke the idle tube on Cub carb
Posted by Shop teacher 94 on July 13, 2013 at 07:47:15 from (192.231.160.6):
In Reply to: Re: Broke the idle tube on Cub carb posted by Kmo on July 13, 2013 at 03:52:34:
Heat....and you may have to chase it out...tap it around a bit with a pick...Careful to not damage that thread.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
