300 fluids
Posted by John17 on July 13, 2013 at 14:57:51 from (74.47.13.182):
Just got my 300, waiting on books to arrive, the problem is the hay needs to be cut. I need to make sure I have all of the fluids topped off, and am a little confused on the hydraulics. There seems to be 2 places to check the fluid level, but I only see one place to fill the hydraulics. The 3 bolts just to the right of the shifter like it will fill the rear end, but what about the center? I am assuming hy-tran is the correct fluid for both compartments. Any and all comments are appreciated, Thanks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
