I use a back blade on a M and have down pressure. Comes in handy for a small hard spot once in a while. Most of the time its not needed. Also unless the tractor is traveling on a flat area when using down pressure you have to constantly move the control. Front tires hit a hump or dirt pile and the blade tilts down and the rear tires loose weight and traction. Even with 4 weights a wheel. I do have a aftermarket valve with float so I can do both. Lots of times I just pull the pin so the hitch will float up without going to the float position. Should do a driveway okay especially if some angle is used. If the blade is a light one some weight could be added as the other poster said.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
