Re: Down pressure for a back blade?
Posted by old on July 13, 2013 at 19:28:15 from (209.86.226.30):
In Reply to: Down pressure for a back blade? posted by BigTone on July 13, 2013 at 17:45:25:
If you think about it down pressure can and will cause more problem them it is worth. Think about the Ford 3 point system which has no down pressure due to the fact with down pressure you loose traction FAST so then your dead in the water and spinning your tires. Simple weight on the blade is by far better
