Are you sure it is not set up as a power beyond valve. A power beyond has three ports (not counting the ones to the cylinders). You have Pressure, Return, and Power beyond. P and R work like any valve as long as a spool is shifted. Flow from the pump moves the clylinder and oil returning from the other side goes to Return. When all the spool(s) are in Neutral, the pump flow goes out the Power Beyond port to the valves down stream.
Power Beyond valves typically are plumbed into the circuit between the pump and the original control valves.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
