Re: Farmall H steering issue
Posted by VMcnew on July 13, 2013 at 20:02:55 from (67.142.168.22):
In Reply to: Re: Farmall H steering issue posted by GordoSD on July 13, 2013 at 17:07:16:
That is the bolt that I suspected. Left front, it looks like a regular hex bolt. I checked the sector gear, and it isn't moving side to side, so the shaft isn't bent. Good observation though. I have another problem now, we sheared something in the steering linkage trying to get the wheels back left. There is a coupler with a U-joint and what ever holds that coupler to the shaft sheared. It was getting dark, so I didn't get to take the bolt out to see what sheared.
