Got lucky when I bought a spool valve
Posted by SDE on July 14, 2013 at 07:37:41 from (72.160.224.171):
I had a spool valve on my 400, that was dumping fluid when the ram would reach the end of its travel. I tried to fix it but it still leaked. So, I bought a replacement at the Le Sueur swap meet. The one I bought had the ability to be reversed. It had two pipe plugs on the back side that could be removed and then installed in the other side. Which is what I needed to do. The one on my tractor did not have the ability to be reversed. My questions are, What model of tractor did this come off of and were all the later valves made this way?
Thank you
SDE
