Re: farmall H clutch
Posted by CNKS on July 14, 2013 at 07:44:27 from (216.144.104.128):
In Reply to: farmall H clutch posted by bmagee on July 14, 2013 at 07:27:47:
You will be much happier if you make the stands in the link (page it down). The H is much heavier than the C. I don't weld so I had them made, and painted the rails inside and out before using the stands. Put duct tape over the rails before using the stands and the paint won't be damaged. I also pulled the engine when it was split. The stands make every thing easier to do.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
