Thanks for the explanation. As I said, I was 10 or 11 to 13 when I used Dad's JD mower and although I'm sure I helped hook it up and service it, I don't remember that much about it. I remember Dad changed the JD from a manual lever when he had it on the JD B to a rod that connected to the Touch Control on the C, and that was the way it operated by the time I was old enough to use it. On the Fast Hitch model, the F-H lifted the entire mower and set the height for the "base" or inside of the cutter bar, but the T-C lifted the bar. As I recall, the bar holding rod was pretty similar on the IH and JD and the IH had a clip and the JD had a bracket with a hole you stuck it through and screwed the "wing nut" back on (Or maybe I have them reversed... been a lot of years).
Either way, anytime I pass and smell a fresh mown field, it takes me back.
This post was edited by IH fan at 09:18:16 07/14/13.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
