Re: cub leaking hyd oil into engine
Posted by Bill Lisbon on July 14, 2013 at 13:41:15 from (69.89.162.207):
In Reply to: cub leaking hyd oil into engine posted by bv on July 14, 2013 at 11:59:00:
Most of the time the hydrulic pump leaks, the seal is shot. The seal wears out because the pump is worn.
