Re: cub leaking hyd oil into engine
Posted by gene bender on July 14, 2013 at 14:13:01 from (67.55.227.12):
In Reply to: cub leaking hyd oil into engine posted by bv on July 14, 2013 at 11:59:00:
If the shaft is worn where the seal rides you will need to have a speedy sleeve installed so the new seal can hold the hy fluid in the pump and not leak into the engine oil.
