Re: Seals needed for an IH B
Posted by gene bender on July 14, 2013 at 15:36:18 from (67.55.227.12):
In Reply to: Seals needed for an IH B posted by Nda on July 14, 2013 at 14:13:23:
There are seals on the front of the tranny and each side of the tranny where the diff shafts go then one at the end of each diff shaft where they fit the final drives. Then one at the front of the engine and one in the steering sector where the front pedestal mounts. One at the belt pulley and another at the pto. Rear seal on the motor could be OK. Ive replaced many seals on those tractors and by now they probably all need replacing all are easy to get at any parts store.
