Re: Seals needed for an IH B
Posted by FBH44 on July 14, 2013 at 16:02:23 from (64.85.217.76):
In Reply to: Seals needed for an IH B posted by Nda on July 14, 2013 at 14:13:23:
Before you rip into it, it might not be as bad as you think. It has [I have to get a calculator] goood grief, 68 years accumulation of grease and dirt. I"d just scrape / pressure wash / wire brush / Windex / soap the thing clean, and run it and just see actually how much grease & oil seeps out. Might not be bad at all. That"s what I found on my "H", only had to replace two or three actual seals. .
