Posted by old on July 14, 2013 at 17:37:34 from (209.86.226.27):
In Reply to: Engine Wants To Stall posted by Scheid220 on July 14, 2013 at 14:15:16:
5th gear is road gear and unless your starting on a down hill 5th will cause just that to happen. You need to go from 4th to 5th and that takes so learning to do to keep from grinding gears. As for it doing that in 4th try choking it a tad bit. If that helps you need to open up the main jet a tad bit
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
