Re: Farmall M Transmission Bearings
Posted by riverbend on July 14, 2013 at 17:42:47 from (65.73.80.218):
In Reply to: Farmall M Transmission Bearings posted by Brady Miller on July 14, 2013 at 08:03:22:
I found that when replacing bearings in my H that the original IH bearings have more balls than aftermarket ( or even current CIH ) offerings. Typically the more balls in a bearing the more load it can handle.
If you are not going to work the tractor, almost any bearing will do. If you are counting on it to get something done, the quality of the bearings might be an issue.
Greg
