Posted by Owen Aaland on July 14, 2013 at 20:51:18 from (216.47.34.191):
In Reply to: 2444 hydraulics posted by Bob2444 on July 14, 2013 at 14:15:16:
For tractors without front mounted hydraulic pump, forward and reverse, and/or continuous running power take-off, my Operator's Manual shows a plug (#24) on the right side of the rear frame housing just ahead of the pivot for the park brake lever. That is just under the platform on the right side.
Tractors without front mounted hydraulic pump but with forward and reverse drive, and/or continuous running power take-off; keep the fluid level up to the level plug opening (26). This plug is located on the left side of the clutch housing just ahead of the clutch pedal.
For tractors with front mounted pump (like mine) the correct level is six inches below the filler plug opening.
Transmission capacity is 5 gallons for tractors without front mounted hydraulic pump or draft control; 14 gallons with front mounted hydraulic pump, without draft control; 17 gallons with front mounted hydraulic pump and draft control.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
