Re: farmall H clutch
Posted by Owen Aaland on July 14, 2013 at 20:58:59 from (216.47.34.191):
In Reply to: farmall H clutch posted by bmagee on July 14, 2013 at 07:46:54:
Unscrew but do not remove the bolts through the frame rails. The bolts need to remain in the frame and backing plate to hold the back of the engine. Otherwise the engine will be supported only bu the front motor mounts.
