Re: Hydraulic lines getting hot
Posted by mkirsch on July 15, 2013 at 06:18:19 from (64.80.110.74):
In Reply to: Hydraulic lines getting hot posted by Roddie on July 14, 2013 at 18:56:55:
The hydraulic system is virtually identical to the Super A, C, and Super C.
SOME heat is normal, but smoking hot is not normal.
Does the engine sound strained when it is idling? Do you hear any strange loud whining when the tractor is idling?
The strainer is underneath a rounded "square" cover held on by four bolts. It is easy enough to pull and clean, but you will need to dump the oil in the process.
