Posted by D Slater on July 15, 2013 at 07:01:25 from (184.14.197.13):
In Reply to: Re: farmall H clutch posted by bmagee on July 15, 2013 at 06:24:57:
Did you remove the starter and the bolt into the engine inside the hole? Also a dowel pin is on each side that it helps to remove them first if they are really tight in the hole. They look like the threaded end of a bolt sticking out of the front side of the steel engine plate. One way on moving the engine, frame rails and bolsters away from the center housing is to put some dowel pins or long bolts in the frame rails to housing holes, one on a side. Move apart enough to install 2 or 4 bolts and a nut back in the rails to steel plate. Them finish moving apart.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
