Re: Early farmall A electronic ignition upgrade?
Posted by El Toro on July 15, 2013 at 08:31:21 from (108.3.218.181):
In Reply to: Early farmall A electronic ignition upgrade? posted by g2reeves on July 15, 2013 at 06:20:25:
You would be better off to fix the mag. NE Kirk repairs them. If the magnets are weak he can recharge them. If you decide to pull that mag you need to look to where your rotor is pointing.
Then make a sketch of where it's pointing, once the mag is off don't move the engine until you get the mag back. Point the rotor shown in your sketch and reinstall the mag. Your mag should be back in time. Hal
PS: My tractor wasn't used during the winter
and since it wasn't sheltered I pulled the mag and kept it a dry place.
