Posted by mkirsch on July 15, 2013 at 13:46:57 from (64.80.110.74):
In Reply to: 350 IH TA posted by Hager03 on July 15, 2013 at 10:19:51:
It'll run practically forever with the TA lever forward if you keep it adjusted.
But if you want to fix it up good, you really need to at least replace the ramp and rollers in the TA. That may be all it needs, and will be far cheaper than a whole new TA.
On the other hand, a whole new TA will outlast you, your children, and your grandchildren's children. If you were plowing for 16 hours a day, 6 days a week you'd need to replace it eventually, but not with the normal hobbyist/collector usage.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
