Re: Early farmall A electronic ignition upgrade?
Posted by gene bender on July 16, 2013 at 02:45:47 from (67.55.227.12):
In Reply to: Early farmall A electronic ignition upgrade? posted by g2reeves on July 15, 2013 at 06:20:25:
get the mag fixed. You cant have electronic ignition without a battery. Clean the points and with the cap off check to see if the rotor lines up with the tower when it fires. The rotor can be out of time a tooth or so makes starting bad. Just worked on one other day started hard so they went to alt and all that stuff when the rotor was off two teeth.
