Re: valve sticking on cub
Posted by El Toro on July 16, 2013 at 09:05:24 from (108.3.218.181):
In Reply to: valve sticking on cub posted by bv on July 16, 2013 at 07:43:21:
If what Old suggested doesn't free the valve I would pull the head. Pull the side cover on the engine block and squirt engine oil around the valve stems. Tap the open valve lightly with the wooden handle of a hammer to close it. Bump the engine over to see if the valve keeps closing.
Hal
