Re: FarmAll H Attachements Size/Type for this job?
Posted by dej(Jed) on July 16, 2013 at 09:13:50 from (141.189.251.1):
In Reply to: FarmAll H Attachements Size/Type for this job? posted by Kevin Rappana on July 16, 2013 at 08:47:19:
If the area was logged over you are going to be up against roots. A trailer plow will grab hold of every one it finds and either unhook, kick back the points, plug up or simply stop you dead in your tracks. An 8 foot rigid(non hydraulic, disk would be the best choice. Be careful with the H because it is light in the front end and can lift up quickly if you hook onto something.
Sounds like a mighty ambitious project for a novice on an H.
