Re: Seat support removal 1951 C
Posted by Lmack on July 16, 2013 at 09:48:54 from (24.131.50.165):
In Reply to: Seat support removal 1951 C posted by Kenneth Stearn on July 16, 2013 at 05:05:21:
If I remember correctly the bolts are 3/8" double threaded with fine threads screwed into the deck and course threads for the nuts. I did the same trick of using a long extension through the top of the box. Where I could I used an impact wrench to turn the bolts out but be careful. The two at the rear of the box were so rusted that I ended up using a cold chisel to cut the nuts. The two at the front came right off. You can use a cold chisel to remove a nut but it will destroy the nut. Often there is no other choice.
