1949 Cub
Posted by Ivan in Mich on July 16, 2013 at 10:20:03 from (174.124.231.168):
I fixed the choke on my cub this morning and to tighten up the little flipper on the choke I had to take the carb off. I turnrd the carb upside down if this matters when I put it back on the trac starts right up but when I shut the choke off it quits. It will not run with the choke off and it does not seem to speed the engine up much when I move the throttle. Any ideas what I did. I also unhooked the linage to the governor could this be on backwards some how.
