Re: valve sticking on cub
Posted by Dalex on July 16, 2013 at 10:35:44 from (108.38.146.180):
In Reply to: valve sticking on cub posted by bv on July 16, 2013 at 07:43:21:
I just did one a few weeks ago that was really stuck. We pulled the gas tank and removed the spark plugs .then we poured some ATF in each cyl and then using a thin screwdriver through the plug holes , we tapped the valves down that were stuck in the up position .We had to do this many times as they were hard to loosen up.We kept tapping and cranking until compression returned to each cyl , then with a fresh set of plugs , it fired up ! Good luck on yours !
