Re: Trying to make her spin..... cub
Posted by mkirsch on July 16, 2013 at 10:51:48 from (64.80.110.75):
In Reply to: Trying to make her spin..... cub posted by anvilheadtexas on July 15, 2013 at 20:53:23:
The Cub starter has a SWITCH on it.
You need to pull the lever after you connect the battery cables.
Odds are you didn't connect the cables carefully and just created a dead short, which is why you got the spark.
The one jumper cable clamp has to be touching ONLY the stud, nothing else, or it will short out. This is very difficult to do with a big clunky jumper cable clamp, and the starter rolling around on the floor.. It is very easy to touch the switch body with the clamp and short out.
Have you tried to spin the starter by hand? It is easy to do.
