Re: Re: Re: Re: Re: Belly Pump Leak
Posted by Bob R on November 25, 2000 at 16:07:10 from (209.198.115.228):
In Reply to: Re: Re: Re: Re: Belly Pump Leak posted by John C. on November 25, 2000 at 15:50:36:
yeah ,
Especially if the seal suface is worn or pitted on the nut.
I am waiting for mine from the machine shop . They will spay coat it with a special torch . will be done right soon I hope . There is also a devise called a speedy sleeve . They are in common shaft sises in 1/16 " increments . And diferent widths . About 30.00 buck a pop . There very thin and have an adhesive so no leaks .
This imfo might help you a lot .
Any luck you wont need it this time .
The speedy sleeve is available a bearing houses .
We have bearings specialty that carry these .
Post A Followup
: Re: Re: Re: Re: Re: Re: Belly Pump Leak
