Hi Mike, as others have said clean hydraulic oil cooler and rad. Very difficult rad to clean properly. Also watch lower rad hose when running at high RPM for signs of collapsing. If hose is collapsing it is time to steam clean the rad. Thermostat or water pump problems as well? Air cleaner clean?
Don't over heat it to boiling or there is a chance of blowing the O-rings on the sleeves.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
