Re: M shifter removal
Posted by Janicholson on July 16, 2013 at 15:45:58 from (74.60.94.18):
In Reply to: M shifter removal posted by BigTone on July 16, 2013 at 13:08:23:
In addition to Gab"s directions, you may need to push down or wiggle on the lever to get a worn pin out of the pivot. There is a kit called : sloppy shifter kit that is available on Ebay. Those who try it are convinced. Jim
