Re: 4th/5th gear (PIC)
Posted by Centex Farmall on July 16, 2013 at 22:28:28 from (166.147.72.154):
In Reply to: 4th/5th gear (PIC) posted by BigTone on July 16, 2013 at 13:00:25:
What everyone else said, also put trans back in 4th and get a giant screwdriver or tire tool and pressure the end of the mainshaft just to see how much play there really is in the pilot bearing.
You could have a compound problem of worn bearing and worn internal teeth for road gear. An old M will put up with a lot of bearing play though and still function well. The rounded tooth ends are from the factory, but sometimes they get more worn from grinding gears. Those look good.
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
